phonoclone 3 roll call
It's a shield separating two channels.
Here's the bottom view:
Hi Peter,
I like the way you applied the regulator boards. I have thought about that some times, but didn't find out how to apply the final connections between the boards in case those are in the middle of said boards. This allows for a tight signal and V+/- routing. Nice!
Rüdiger
Peter,
You indicate that you use 627/637 that raise two questions:
I asume 627 first stage and 637 second, correct?
Did you do any decoupling on the opamps
Thanks for the info.
Did you compare 27/37 with 627/637, if so what is your impression the significant difference?
Your geometrical solutions and machining skills always envy me.
It looks great (and probably sounds likewise)
Michiel
