hey there
now i dnt know if this is in the ryt section but here it goes anyway.
I HAVE SEARCHED AND NOTHING COMES UP TO MY QUESTION
u c my bro gave me his old sony lbt-n200 hifi with speakers, now i blew the left channel about a month ago and repaired it but then i wanted to run it as my main hifi in my room since it has very big power. but there comes a problem . the hifi only has phono input and no aux.
so is there anyway to convert the hifi into aux
thnx
Ruvs
PS: the cd player does not work so mayb i can tap the audio signals from there
Plz any help will b greatly appreciated
thnx
Ruvs
hey
wll unfortunatly i cant get hold of the schematics but will a picture of the phono board help
thnx
RuvenDRAN
thnx
RuvenDRAN
You need to find the point on the INPUT SELECTOR switch that selects the Phono input - i.e., where the phono preamp output connects to the Input Selector switch.
Cut that connection, and link those 2 points on the Input selector directly to the Phono RCA jacks. Cut any original connection the Phono RCA sockets had to the preamplifier circuitry.
This will bypass the phono-pre amp.
You can pull out the input and output capacitors in the phono stage,
(1 to 10 uf ) this will leave 4 connection points.
1. input from RCA
2. Preamp input
3. Preamp output
4. Main amp input
jump positions 1 and 4 with a axial 4.7/35 capacitor. polarity same as input capacitor
1. input from RCA
2. Preamp input
3. Preamp output
4. Main amp input
You can build an "inverse RIAA" filter which will attenuate and equalize line level signals to be compatible with phono inputs.
http://www.epanorama.net/circuits/phono.html
