I was thinking about the fact that when I build a solid state phono stage I always have a lower noise floor if I have the transformer/power supply separate from the the device. This also holds true for my Technics SL1200 turntable, taking the transformer out lowered the noise floor.
I have a Hagerman Cornet 2 phono stage which has the transformer on top behind the rectifier.
My question is: Do you think moving the transformer away from the amp would lower the noise floor?
BTW I was an electronics tech in the 70s and am aware of the issues with a high voltage umbilical. 😱
I have just completed a valve mixer and the transformers were a bit too close to the input circuit and caused lots of hum. So moving the transformer away from the valve and audio circuit makes a lot of sense.
Just make sure any high AC voltages are kept away from the valve and audio circuit.
