Hello All,I am new here and a bit of a dunce with electronics but I have some time and like mucking around.
My question is; "Is there a digram or instructions to build a simple preamp that would go between my turntable and computer out there?'
It would need to be inexpensive,easy to construct, and it should work ok and possibly be powered by 12 volt from a 240/12 volt transformer like the ones used for cordless drills etc. I am ok at soldering ,like a plumber, and don't understand all the technical stuff here but can put things together all right.
All suggestions appreciated thanks,
Wombil.
Wombil.
Please Note: PCBs are available for this project. Click the image for details.
Unless noted otherwise, all PCBs are sold as a bare board, and no components are included.
http://sound.westhost.com/pcb/pp06.htm
If you click at the link you'll have gotten then answer 😉
