Phonic Max250 or Behringer A500 for speakers 93db??
Still can't make my mind up on which power amp to buy.
1) Phonic Max250 - 60 watts x 2 at 8 ohms (will be buying 2 amps to upgrade with X-over at a later date).
2) Behringer A500 - 160 watts x 2 at 8 ohms (2 again amps again)
As my Kipsch F-1 are so sensitive maybe I get away with the Phonic amps and save myself 180 USD.
Time is ticking as my local store os offering 25% off with my bank visa on Tuesday!!
:bawling:
I have no idea re the Phonic, but all else being equal, more power is not a bad thing.
My forthcoming speakers are more sensitive than yours, and I am specifying more power than this to get the clean peak levels I desire on occasion.
Don't forget the active xover.
Hi there Brett,
Can´t find 1 single review on the phonic.
Kinda strange as I understand this company has been around for some time.
I like the slim design on the phonic but concerned about the power output. Hard to imagine there is a power transformer inside considering how slim it is.
Hi!
Brit01 said:
Hi there Brett,
It is very simple class"H".
Older brother is MAR1.Great Amp. low profile!
Regards zeoN_Rider
Why on Earth would anyone build a 60 watt class H amp, unless they wanted a long run time off batteries?
Could you elaborate on your comment?
Sorry for my ignorance. I am just learning about the different classes of amps and tranformers. A newbie with a lot to learn.
Would this 60 watt (8 ohm) amp not perform well? What would be the consequences or typical use of this type of amp??
Cheers
Cheers
It would perform perfectly well. Class H reduces waste heat. But a 60 watt amp doesn't generate enough of that to get upset about. It does cost a little more to implement, and all other things eqaul, won't sound quite as good as the same amp in class B (AB).
Hi!
Why not? look att. 200VA/4 x 22V, each.
Regards zeoN_Rider
