ManUtd said:Hi to All,
Is there someone who has scematic-diagram or Service-Manual
for Philips CD-960?
Any links or..........
Thanks,
ManUtd (It`s a GOOD team)
Hi ManUtd,
I have. Please contact me by email.
Andypairo said:Hello Elso, how much do you think this DAC is worthwhile?
Cheers
Andrea
? Can Dac inside be changed
Cheers
Andrea
Hi Andrea,
You mean the DAC inside, as the CD960 is a CD-player?
The CD960 is built like a tank but circuitry looks very much the same as the CD650. I have experience with two CD650's and I find the CD931 much better as a transport. I don't use the built in Bitstream DAC though it is not very bad.
Nicer Machines
Such as?
Better sounding as a transport?
jean-paul said:CD931 really is not well designed. There are several nicer machines between CD650 and CD931.
Such as?
Elso Kwak said:
Hi Andrea,
Sorry, I made some confusion... I meant DAC960
Cheers
Andrea
DAC960
Hi ,
The DAC960 has the TDA1541 inside and a Philips receiverchip.
I am not a fan of the TDA1541 but others are. In the Pooge Chronicles and in the Audio Amateur a lot of mods are presented by Walt Jung and Hampton Childress.
Cheers
Andrea
Hi ,
Positive is that CD931 has CDM9 which is quite OK. Now compare with an Arcam with CDM9 in it, you'll be surprised.
I have the Philips 950 and the Arcam Alpha 5+. Both use CDM 9 transports. IMHO, the Philips 950 is much better than the Arcam.
Re: CD960
Thanks.
How about the Philips 880 aka Marantz 85? I have one but I don't know what lens it uses.
Any idea where to get CDM1,2,4Pro?
Elso Kwak said:
CDM1
Thanks.
Philips CD950
Hi Prometheus,
Isn't the Philips CD950 very similar to the CD931 and 940?
Pictures from the CD931 here: Ooops forgot where. Bricolo has the link.
Hi Prometheus,
Question
Hi Jean-Paul,
Thanks,
Now I have your attention, could you please answer this question:
http://www.diyaudio.com/forums/showthread.php?postid=244395#post244395
Thanks!
Hi Jean-Paul,
Thanks,
Thanks!
Re: Question
He likes Arcams
Elso Kwak said:Hi Jean-Paul,
Thanks,
Thanks!
He likes Arcams
- Digital Source
- Philips CD-960
