Philips cd 304 Mains Transformser
wckong said:
I need help for my damaged Philips CD 304/01 mains transformer (220v 50Hz 30W). Can someone kindly provide me specification or schematics for this part# 3112 318 39711 (WA 514) so that I can ask someone to re-wind it.
I have SM for 304 - contact me - balakin_e(at) yahoo.com - and I'll replay to you with sm,
4.38MB , german lenguage
I have the diagram of CD-104. If the transformer is identical, here are the voltages, all AC:
1-2: 110V
3-4: 110V
4-5: not indicated (could be 20V)
2 and 3 connected
6-7: 8V
7-8: 8V
8-9: 7V
10-11: 7V
12-13: 10V
14-15: 10V
16-18: 2.3V (17=center tap?)
6 and 11 connected
9 and 14 connected
10 and 13 connected
Colors:
6, 11: grey, RED
7: blue, green
8: black, BROWN
9, 14: brown
10, 13: green
12: brown
15: black
16: yellow
17: grey
18: red
I hope it helps.
Philips cd304 Mains Transformer
Re: Post #3
Hi, Bernhard
Glad to learn that you can offer a replacement transformer. Please advise the total cost & payment method. It would be much better than asking someone to re-wind the damaged one. You may contact me by :
wckong1950@netvigator.com
By the way, i would like to thank all who response to my Post#1
Re😛ost#9
Hi Oshifis,
Thanks for your reply to Post#1. I suppose the configuration of cd 304 & cd104 are similar in respect of the mains transformer, for the power supply unit uses the same type of three-terminal voltage regulators.
I wish that I won't mislead you, since my knowledge in this field is limited. Maybe some other experienced guy could tell the true story.
Anyway, thanks again for your two posts in this thread.
Best Regards.
Change trasformer about the cd 304
Hallo
I would change the original trasformer about my philips cd 304 the diagram is not very clear for me
I thought buy a trasformer about this test point:
30vac
8vac-0-8vac
80vac
About the display is critical,the diagram say 1,25vac-0-1,25 but i misure the 2,4vac-0-2,4av and i don't know what i use
Have you exeperince about it?
I though buy a toroidal trasfomer about 100W
Best Regard
Paolo
