Hi everyone,
I have a very good condition Full Range drivers Philips AD 80800/M4S, I don't have the parameters and other details, does anyone have it ? I will be glad if you can write me the parameters !!!
Also can anybody recommend me about the size of the cabinets for this drivers ?
Cenk
Cenk
sure !!! pls find followings :
best bet - OB with bass helper
next - Infinity baffle box ( meaning - as big you can make )
in case with bass helper - cross it with series cap , so not put anything else in signal path
if you're curious - you can find on-line tutorials for measuring T/S parameters .
I made some extensive search for some other Philips drivers ( for T/S) but there is almost zero drivers covered with data needed for any simulation
Try to search Dutch or Belgian diy forums. The only sheet I have from Philips is meager. Written only 85hz fs.
Peter
Peter
This is the most comprehensive list of vintage Philips luidspeakers I know of.
http://www.mfbfreaks.nl/pdf/div/philips_luidsprekers_1980.pdf
Hope it helps.
Greg
Hope it helps.
Greg
page 49 - 50, t/s parameters included
http://elektronik-lavpris.dk/files/sup7/philips_loudspeakers.pdf
- Full Range
- Philips AD 80800/M4S
