Guys I have a ms2125 that is powering up but the driver circuits LED'S are not on. I found a bad LED on one channel and replaced it. Ow that channel is working. The right channel however is not working. The rail voltages are equilized though. If I ohm'd all the resistors on that channel and everything looks good. If I measure voltage across the led it reads around 200mv and about 1v on the opposite side. Any ideas or a schematic for this amp?
