Phase plugs for Betsy
frugal-phile™
Joined 2001
Paul suggested i start a thread to let people know about these.
Due to an error* by the people that make my phase plug blanks i have about a dozen pair of plug blanks i'll sell.
*(they pulled out the B200 template to make FE16x plugs and i ended up with something that was in between, and work perfectly with the 2 pair of Betsy i have)
If i was to finish and retail these they would be $40/pr, i'd like to just move these out unfinshed for $20/pr (with or without pre-installed magnetic fixing).
Note that it is tricky to remove the dustcap without the whizzer following along. It is possible thou -- i will post pictures. If you remove the whizzer you end up with no dustcap.
I will also send a handfull of these to Paul so he can play with them, and maybe a lucky few can get them shipped with their drivers.
dave
frugal-phile™
Joined 2001
Pictures as promised.
dave
nice EnABL & plug work - Dave, is the whizzer attached to the former such that if one opens up the dust-cap to see the former that careful hobby knife work will remove only the cap? (I removed the flat cap on Eminence's B102 and that dustcap/whizzer) part is supplied one-piece. Did it lose any top end extension? There ought to be someone who would machine metal plugs for a low cost? - - are there paper cones for 12" as nice as used in Betsy? - fwiw wish there were really good 12" fullrange with real 2mm xmax
frugal-phile™
Joined 2001
Thanx Freddi. One can get the cap off without detaching the whizzer, but you have to get really careful as you approach the coil. On the 1st one i did, i loosened part of the whizzer which quickly made me realize tht i was dealing with the same issues as i had on Nanooks MISCO made HA FR8c (his whizzers were munched so he said just go a head and loose them). A little glue after the fact reattached the whizzer where it had come unattached. The 2nd one i was more careful with and got it done without that issue. One should consider some reinforcement of the joint regardless (a little modpodge works there -- i was from the get go modding them so the modpodge is just part of the routine anyway)
dave
Joined 2004
Hi Dave,
I just sent Paul the $ for a pair of each of the Betsy and BetsyK drivers. He doesn't have any phase plugs available for sale - have you got any of these left? I'm looking to mess with them one step at a time - tweeter experiments, mortite and/or felt on frame, modgepodge, etc. They might be my first enABL efforts as well!
Best regards,
Pete
