Peter Daniel What type of fasteners are those?
That you use on all of your chassis. It looks like a countersunk washer that you can use in order to get some flexibility by drilling your holes a bit larger. Into the countersunk washer fits you cool screw.
Where do you get those? I would be very interested in buying the washers alone for some size 8 counter-sunk screws.
Thank you,
Paul Hilgeman
It is a high tolerance brass bushing with 0.25 inside hole and 0.50 mounting hole. It accepts shallow counersink screws.
I don't use them much, mostly in the preamp, but I'm running out of them quickly. They come form aircraft industry and I would be interested myself, where to source more of those.;)
Of course, I have impact guns. I even have an offset collar installation tool (by Atlas) ;)
And I have some local friends who currently work in the industry, but I'm always on a lookout for nice fasteners.
I somehow never thought about using Hi-Lites in chassis building, but maybe it's something to think about. I used rivets recently, and I'm very satisfied with results.
They are not sqeezed too tight, I made counersink for lower manufactured head size ;)
Let me know if you want some, I will make you a good price but without any tracability (That the reason I'm able to sell it =)).
I will check the quantity I have in stock.
Coulomb said:
If you use a Dewalt Pilot drill after you drill with a standard drill for the rivet hole, you will get a nice little ledge to catch the Rivet head and have it flush to the material surface.
We prefer to use more advanced tools;)
BTW, the list price of that pistol drill gun is close to $1K, if not more.
