Pentode loaded with a IT like LL 1660
Pic.
You can, but you need to load your pentode in order to get acceptable frequency response out of an IT. Then you'll have to check, by looking at a loadline for example, if the loaded pentode delivers the gain you need.
Otherwise you'll need a specific pentode IT which translates to hundreds H of primary inductance, little to none and careful interleaving. Overall capacitance must be kept in the pF range, I'd roughly say 100pF max.
For the price of such an interstage transformer, that actually has hundreds of Henry, and no more than 100pF . . .
You probably can purchase any one of several models of inexpensive tube amplifiers, or inexpensive amplifier kits (yes,
those inexpensive amplifiers may not perform real good.
But for your amplifier, with all that $$$ on the interstage, you still have to purchase all the other parts $$$ too.
And, an interstage with that many turns is going to be super sensitive to any magnetic hum fields, especially if it is a single ended air gapped transformer.
