Pensil 10P's / 2 watts tube
I'm building the Pensils/10P's. I have a Decware Zen Clone I built from their schematics using Edcor Iron. My listening room is small 11.6L x 9.5W x 8tall. I only listen at low volumes. Will the two watts be enough for the 10P's at low volume? I like tube SQ but, I can use class D also.
I'm also looking to buy a new preamp & amp. So I'm open to suggestions if the Zen is marginal.
Thanks,
Mark
frugal-phile™
Joined 2001
Only you willknow when you fire them up.
With the Edcor iron your amp will be better into higher impedances than the Decware. In a small room at lowlevels it is likely sufficient.
If the <2 W is insufficient you can approximately double that by wiring the EL84 in pentode and apply Scade/RH84 style feedback. That and using all Solen poly caps in the power dupply made big improvements in the SE EL84 journey we started with a Decware clone.
nice build on the ZenClone - for the size of room described, I think you'll get lots of enjoyment once amp and speakers are fully broken in.
tell us about the barbells?
As to pre-amp - what will the source(s) be? If mostly digital there are some pretty decent (& incredibly convenient) DAC-pre combos to be had - otherwise how about something like the Grounded Grid?
The barbells are for me to get my strength up. :smash: Really there for the spikes/stands. Not sure I'll use them. Well see after I router the edges.
I built the amp last year. I'm using MLTL's with BetsyK's, alignment by GM/MJK right now. I expect a big improvement in SQ with the 10P's.
I run source direct on the CDP. For my vinyl, I use a CNC phono stage that's battery powered. I haven't tried the system with my PC, Modi dac.
Mark
Here's the phono stage. Made to match amp.
One down, one to go. The CNC cut flat pack sure makes for a quick assembly.
Have the 10p's sitting in their shipping boxes burning in. I tried the Zen and it's going to work great. I have a TPA3116 running 24/7 with them now. Gotta save the tubes. :D
Thanks out to StevenZ for the CNC flat pack and introducing me to the MarkAudio drivers. I should of done this along time ago.
Mark
Both boxes are done. Just need to sand and finish. Thinking about using Duratex. I tried Danish oil on a piece of the wood. It looked nice but, I don't like the ply ends showing.
Mark
Mark - by the time all the prep is done to get a paint job that doesn't telegraph the ply edgegrain, wood backed veneer could be faster and cheaper. :)
Then just clear coat with oil, varnish, sprayed lacquer - your choice.
Of course I say that as I'm not at all a fan of painted enclosures - YMMV.
Thanks Chrisb, I'm still thinking on it. I could veneer. That is what I would really like to do. The Duratex is a roll on paint that's like bedliner. It does hide the end grain. It applies direct to bare wood and is tough. I have a few days to think about it. Had to order binding posts etc.
Mark
You can also have a look for edge-banding for the ply edges. I've done some shelves and things with it and the effect is pretty convincing. Just make sure to get real wood (birch), not a plastic wood-look-alike.
As the boxes are already fully assembled, the iron on veneer edge tape would sit as much as 1mm proud of the adjacent panels, and would be hard to trim & clean adhesive seepage on the "inside" edges.
In commercial millwork edge banding of any type is generally applied to panels and trimmed / finished before assembly.
Another alternative would be to chamfer the front edges at 45' and apply a thin strip of solid of either matching or contrasting solid (3M #203 construction grade masking tape is your friend). Use sanding block to get level with front / sides, then give the whole thing a sanding down to at least 220g and apply finishing products of your choice. Saves veneering the whole box, and can look like it was meant to be that way.
