I have a pair of the Peerless CSX 6.5's and was looking for some really really nice bookshelf designs using these.
http://www.partsexpress.com/pe/pshowdetl.cfm?&PartNumber=297-632&DID=7
Any help is great.
Any help is great.
http://www.speakerbuilder.net/web_files/Projects/peecreek/pcrkmain.htm
Seems a good design for the crossover, box design could
be beefed up, see some other designs for inspiration, e.g.
http://www.northcreekmusic.com/CM-7/CM-7_Cabinet.PDF
🙂 sreten.
🙂 sreten.
well, i was going for the peecreek thing, but i hear speakerbuilder.net isnt that good. I know i have a great woofer, with alot of potential, so im looking a great design using it in a 2-way.
Huh ? what do you mean "isn't that good".
IMO the crossover designs are first rate, but cabinet design
and optimisation aren't Wayne J's forte, thats up to you.
You won't find a better crossover design on the net,
and the Peecreek is an excellent implementation of using
the driver, the NC tweeter is simply excellent for its price,
superb if you believe the blurb NC say about it.
http://www.northcreekmusic.com/Drivers/NorthD25.pdf
IMO as long as you keep the baffle width ~ the same you
can build a cabinet any way you like. So if you build the
speaker according to NC cabinet building and wiring
guidelines you are on the way to a very good speaker.
Personally I'd make it around 21L (0.75cuft) reflexed around
35Hz if a sub is not going to be used, or make it 14L (0.5cuft)
sealed if a sub is going to be used.
http://www.kaiaudio.com/diy2001/jasonopen.html
Is another design but I don't like the crossover (at all).
🙂 sreten.
🙂 sreten.
i dunno, i always thought his designs were great too. A sub is going to be used, and i already have a pair of .5 cube enclosures, built to waynes specs. Anyway, i saw that design, i liked waynes better. So, .5 sealed it is. Also, what would you advise as far as caps and coils? poly caps and air core inductors? What about the resistors? Also, what should i like the box with? Acoustic foam, fiberglass, or poly-fill? Sorry for all the Q's.
For a sealed box line with foam and lightly stuff with Polyfill.
WJ box design isn't all that, but then again he was simply
copying a prefab PE cabinet, NC's approach to cabinets
is more like it IMO if your serious about getting the best
out of the driver.
Poly caps, air cored inductors, non-inductive resistors.
🙂 sreten.
out of the driver.
🙂 sreten.
So ? same tweeter different bass unit.
Internal volume is 0.5 cuft, so all you'd need to do
is slightly modify the bass unit mounting details and
omit the vent from the rear.
I'd just cutout a hole in the rear panel but leave the
plywood panel solid instead of using a terminal cup.
Would be perfectly fine with the Peecreek crossover,
and obviously built to a far more solid standard than
the PE cabinet or WJ's version of the PE cabinet.
I'd also offset the tweeters for a mirror image pair.
With the large roundovers on the front baffle IMO
any difference in baffle size would be a non-issue.
🙂 sreten.
🙂 sreten.
0i dont understand why i should offset the tweeter, will that mess with the xover? And my cab. is .5 cube, but a little deeper too make room for the braces. Its a solid cab, made with MDF and assembled with liquid nails and drywall screws.
I'm just giving suggestions, it up to you what you do.
The tweeter offset if you do it is not enough to upset
the c/o, NC suggest 3/4" which sounds about right.
I can't see any mention of braces in the cabinet details,
you did say to WJ's specifications.
The NC cabinet I just pointed out for design details,
e.g. the bracing is easily added to an existing cabinet.
Also the baffle rounding is a very good idea IMO.
I'm getting a little lost, you've built the cabinets, you have
the bass units so why are you having second thoughts ?
Have you finished off the cabinets or are they still basic MDF boxes ?
🙂 sreten.
🙂 sreten.
Mirror image pairs always look more serious 😉.
TBH I'm not sure what your looking for. The PeeCreek c/o
and tweeter should be fine. What you can do IMO is improve
the somewhat basic PeeCreek box design and here to an
extent its going to take some imagination at least.
🙂 sreten.
🙂 sreten.
- Peerless csx
