peerless 830668 in TQWT?
don't forget the QW of TQWT stands for quarter wave or wavelength. that particular calculator is tuning the enclosure for the driver's FS.
"Line tuning is set to Fs of driver to critically damp it at that frequency."
your driver having a low 30hz-ish FS, makes sense on the line length.
a 100cm line length will raise tuning to the 70-80hz range, which isn't much of a subwoofer at all. If looking for a smaller line length, try simulating or calculating a TL or MLTL. Brian Steele has a great excel spreadsheet for MLTLs, and TLs can be designed with aggressive tapers to reduce line length
