Peculiar Sovtek EL34 bevaviour
Ex-Moderator
Joined 2004
I have been happily using Sovtek EL34s in a stereo p-p amp that I have been developing for the past year or so. I am using fixed bias for the EL34s, with a separate 10 ohm resistor in each cathode so I can check quiescent current to adjust the bias. The EL34s are connected as pentodes.
Yesterday, I measured the cathode currents and found that one pair of EL34s was behaving normally but the other pair had gone completely nutzoid. :xeye: One tube of the 'bad' pair was drawing almost no cathode current at all (about 1mA), while its mate was drawing 125mA! I had previously biased them for 40mA each and I found that readjusting the bias pots made no difference. I tried swapping over the 'bad' pair of tubes. I also tried moving the 'bad' pair from the right-channel to the left-channel, and vice versa. Whatever I did, the same tube consistenly drew almost no current while its mate guzzled 125mA.
I'm sure that the circuit cannot be to blame for this phenomenon, since moving the tubes about makes no difference to which tubes are misbehaving. I must, therefore, have a pair of bad tubes - but what I can't understand is: why one tube should suddenly stop conducting while the other suddenly starts taking 3x its normal current? Any ideas, please?
I suspect that the tube that is drawing no current , is shorted in the grid , so all the negative bias voltage of that pair disappear.
Then , the other tube of the pair, is working hard without any negative bias.
Inspect that..
Hi there....I had a fault like this which costed a pair of good 88's in an MI amp....fault suprisingly was a busted g1 contact in the valve holder.:bawling: Thinking it was a tranny problem and o/p stage in HF take-off, the other half was glowing rather....until I knocked the replacement tube into contact just before the other was going to melt down.... I always check the soldered contacts on the tube pins on octals.
richj
Thanks for your replies. I have tried various combinations since I last posted, including the "bad" tubes on their own (single-ended). Nothing seems to help: 2 of the tubes are OK and the other 2 are not.
I've been doing this testing with dummy load resistors in place of the speakers and I've noticed that the channel with the "bad" tubes has a large output signal, which increases in amplitude if I increase the volume control. It's as if whichever channel happens to have the "bad" tubes is oscillating and/or is extremely sensitive to noise at the amp's input. The channel with the "good" tubes seems perfectly silent.
I believe the design of my circuit should mean that each push-pull tube is independent of its mate, in terms of both grid bias and cathode current. So, I think they should operate independantly and I can see no reason why one tube drawing excessive current would cause the other tube to draw virtually no current at all (or vice versa).
I've checked with an ohmmeter for short-circuits between electrodes in both "bad" tubes and found nothing wrong. However, richwalters' suggestion to check the soldered contacts at the tube pins makes good sense and I'll do that ASAP.
Hi there.....I'm not sure how you want to proceed but my way is given...beware of the hoax.......With fixed bias UL circuits one side can effect the other.....not only though the bias......How ? Through the UL screen/ anode tap as the output tranny is common to both tubes. If one tube is duff or really unmatched/ gain current hungry it can stir up the leakage induct/cap reactance properties into ultrasonic oscillation activated by a small amount of gain from the good tube...and go into crazy motor-boat conduction pulling down g1....this condition is a suspect hallmark of UL using high gm tubes. A standard DVM will go display crazy with the RF......the only sure way to detect oscillation is with an osc'scope. However;
This is a serious bench test.....My way of checking instability in the output stage or feedback loop is to temporarily remove the feedback loop from the secondary of the output transformer (that goes to an input tube). Beware an amp in this condition only requires a few 10's mV for full output. Dummy load the sec with good wattage resistors....then see how the DC conditions of the output stage behaves with no input signal. Measure currents and if settles down then we shall deal with the next problem. The nfb loop can cause oscillation if any component is busted.........you can try this test with the other channel for comparison. .........that will reveal if you have a real DC or AC problem. If this is too much then try this:
A simpler way is to remove the output stage driver tube/s (if there are any) that also effectively breaks the nfb loop. (so long they have interstage caps) Then you will be running the o/p stage alone.......and should be peace and quiet to measure.
I'm not sure of your diagnostic ability....beware of the DVM with the B+...not all meters like it mixed with RF....
In any case I've mentioned the above ......for others to comment.
richj
Hi Rich,
I'm OK in my field - it's only when I get into towns that I have a problem😀
Your suggestions about testing make sense, although they can't all be applied in my amp. My only feedback loops are cross-coupled, from the OP tube plates to the 6SL7 LTP phase-splitter plates. In between are 6SN7 drivers. Also, I'm not using UL - my OPTs don't have the necessary taps or tertiary windings, otherwise I probably would. And I don't have a DVM, just a moving coil multimeter with 50uA basic movement.
The fact that both channels behave normally with the "good" tubes (as far as I can tell), and both behave abnormally with the "bad" tubes, leads me to conclude that the EL34 tubes themselves are the problem.
I haven't had time, yet, to try remelting the solder joints at the ends of the pins but I'll certainly give it a go. Who knows, it might fix the problem. Suppose, for instance, that the tube that draws almost no current has a break in the cathode connection. Then the only current that could flow through the cathode resistor would be from the suppressor grid. And suppose that the guzzling tube has a break in the suppressor grid connection (making it a tetrode). Could this cause excessive plate current, do you think?
peculiar behaviour Sovtek 2A3
I have some Sovtek 2A3 tubes which I bought some years ago from a guy in Russia. At least I suppose it is sovtek. It only has 2A3 in small black letters on it and a number 007, the other 008 and so on.
I tried 3 of them in a dc coupled se amp. They all measured fine at the start. After about 2 hours 2 of the 3 tubes began to play softer and one of them started to distort (I did stopped earlier with the other bad tube for safety reasons). I could not measure during playing. I switched the tubes on my two monoblocks and the problems switched to to the channel with the bad tube.
Just curious😱
What can this be ?:scratch:
Should I put them in the trash can in stead of in a amp ?:smash:
regards,
Jaap:santa2:
Re: peculiar behaviour Sovtek 2A3
Hi there......Sad case you got given tubes that were just at the end of their life. I've had 88's do this....my ones went current hungry and eventually........psssssssssss inside .
Bin it
richj
Feedback: One EL34 was no good and that was causing its mate to go crazy. I can only assume that the cross-coupled feedback didn't like being loaded on one side only. Anyway, I've now replaced the four Sovtek tubes with four Svetlanas and everything seems OK.
Hi there......UL circuits when running per spec are quite stable, but when conditions on one side go haywire (as you mentioned) then everything self destructs. High gm tubes are notorious for self oscillation when RF tank loading conditions prevail.
Caveat Emptor.....get your tubes from a good reliable source as I do. Insist whoever tests or matches them to also tap/rap the envelope side which might show up any poor mechanical assy. This happened to a batch of Ei KT90's so I tossed the lot out. So many vendors seem willing to give stuff to the amateur market which has already been through someone elsesback door. Unfortunately most of these are in the US.
Facit....the nicest thing about int octals is the versatility of interchanging tubes....in suspect circuits.....most of the audio power tetrodes/pents are interchangable.......only that the biassing requires a tweak....bear in mind the B+ value.
richj
