Peculiar behaviour displayed by the NAD 208 THX amplifier
Thanks @kapitiaudio for your comments. The tech's feedback was that the relays and the driver IC look OK. I am not sure if they checked the thermal switches. I did mention to them about how the amp's relay clicked pretty much immediately when used every day or every other day, but displayed a significant delay when operated after more than 3 days or thereabouts. As much as the lads at NAD want to fix the older amps, they are limited by the resources given to them to diagnose these issues properly. I believe it is a policy issue more than anything.
Thanks @Mooly for the reply. Sorry about not responding earlier, as I had something urgent to attend to. I have to report to you that something else happened with the amp.
Yesterday, I powered ON the amp, and it took around slightly more than 1 minute for the relay to click. The preamp had the volume set to 'mute'. When the relay clicked, the LED did not change to GREEN but remained AMBER. I could hear hisses and buzzes from the drivers. I believe it was not loud because the volume was set to mute. I switched OFF the amp immediately.
I waited a few minutes and powered it up again. This time, the relays clicked within a few seconds, but the LED still remained AMBER. With a second or two, there was another click. Still, the LED remained AMBER, but a loud pop went off in my speakers. I switched it OFF immediately.
I have not encountered this in the past. This is the first time I am seeing the amp's relay clicking and the LED remaining AMBER. Usually, it clicks(regardless of the time it takes) and the LED will be GREEN.
Wondering if I had blown by drivers, again, I disconnected the speakers from the amp and plugged them directly into my preamp/streamer. Appears to be OK.
@Mooly Hello Mooly. Thanks for the quick reply. It was the speaker drive units. If I had not set the 'mute' switch ON on the preamp, I think this would have really loud. This will go back to NAD next week. If they can't fix this, I will send it out to a local tech. In the meantime, I am looking to order this scope:
https://www.amazon.com/Hantek-DSO2C...47233506&sprefix=oscilo,aps,1124&sr=8-12&th=1
Do you think this would be enough to get around fixing this amp? Or is it overkill? I might even bring this to them 🤣 . Unbelievable, it is, Mooly. I was so glad and pumped up after the initial fix.
A scope like you show is OK for basic audio work... its fine for that 🙂
Your latest problems are probably more fundamental and initially at least back into traditional faultfinding with a meter. You have to check the basics (the DC conditions first) now the fault has gone to what you have now.
