Hello,
I've a Classic 30 with two problems. The overdrive cannel don't work, and when I switch off the amp they make an horrible noise. I try to change vacumms and nothing... the problema still there...
https://vimeo.com/154967320
Anybody can help me?
I solved the problem with the overdrive channel, I found copper trace problem with R11, C1 and R5.
But the shutdown noise persist. I discovered that when I pull down the reverb the shutdown noise dissapear... Porbably reverb tank damaged?!?
