slightly offtopic
offtopic but I did not want to start a new thread.
Please find attached famous transtube circuit. Peavey claim that this topology gives good sound.
I simulated it and looked for soft clipping like in tubes, but does not! Even not hard overdrive gives sharp waves.
Could enyone explain why Peavey used this solution?
What is a benefit to collect a signal from both collectors?
Do transtube versions sound better than with only opamps?
regards
P
regards
P
There is a LOT more to a tube sound than just how it clips.
The transistors are wired together at their collectors as a Darlington pair. Look that up. The point in the Peavey circuits is that it tries to make the stage act more as a voltage amp than a current amp. That is said to more resemble a tube stage.
From the Tech Notes on the Peavey web site, the transtube section:
http://www.peavey.com/support/technotes/hartley/chapter_3.pdf
Welcome to the forum, pad. I don't know why you wouldn;t start a new thread, they don;t cost anything. And that way you would get better response than tacking on the end of a 2006 thread. Likewise linking from the end of a 2004 thread is not the best way to get noticed.
Enzo said:
Thanks Enzo
this paper explained a lot,
probably I will do not start a new thread
regards!
P
I have this same diode in a peavey that has discolored leads like it may have heated up. Since this diode is a double deal does it check out like a typical single diode?
