I'm getting ready to build a Pass Pearl phono stage. The cartridge that I'm using is a Ortofon Kantrapunkt A which has 450uV ouput voltage and a recommended load impeadance of 50-500 Ohm. I will run the phono stage into an active preamp. Will this phono stage work with this set up or will it have to be modified some how?
GE
GE
