Pearl 2 woes
Shouldn't be any DC on Pearl2 output unless the output cap was bypassed. Check status of output mosfet as they are very static sensitive. Are you sure it's not an amp problem? Can't see how the Pearl2 would cause amp to shut down.
TJ
The Pearl 2 will normally put an amp into protection mode if the amp is powered on first. I reported this in another thread a while back. Best to power on from the source and power off from the amp.
One of my Pearl 2s once got kind of silly with oscillation and needed to be powered off for a while before it returned to normal. Hopefully in your case it isn't too serious of a problem!
There's nothing wrong with the unreg raw +/- PSU.
