Pearl 2 - Destroying Pre-amp inputs
A few weeks ago I had to substitute my Pass B1 and Aleph 4 with my trusted Arcam AVR280.
Unfortunately my Pearl 2 instantly destroyed the input ICs on the Arcam.
After a bit of investigation I found that the Pearl 2 outputs briefly swing to almost +24VDC on power on.
The B1 can cope with that.
The Aleph 4 has zeners on its input to protect it.
I'm just replacing my B1 with a P1.7 together with a RCA to XLR convertor, simply to be able to use balanced connectors.
I can't find anything on the THAT340P datasheet to tell me if the new pre-amp can survive the 24V pulse from the Pearl 2 ?
I've got a reverse zener input box that I can use but I'd rather not use it if I don't need it.
There is an error on the schematic for the pre-amp, it is powered with +/-20V not 30V as shown.
Yes the Pearl 2 has output caps but the DC pulse can still get through.
The Pearl 2 is built on two original Pass DIY boards with all the recommended components.
The PSU is remote.
Hi Mark, I concur with that thread. It is a simple case that one rail draws more than the other on startup.
Going back to my original question, can the THAT340P cope with that pulse ?
My PSU uses dual bridge rectifiers with a pretty huge 22000uF / rail power supply.
... I power Pearl, then pre, then power amp.
Yep, this is my protocol as well. Either power on the Pearl first, or make sure the input select is set to a non-Pearl input.
In one setup, I run the Pearl into the Korg pre, then to my MoFo. Powering the Pearl sends a surge into the MoFo that trips the protection of the laptop power brick that I use for the MoFo. That's when I figured out the protocol above 😉
This post is more an informational post about a slight design flaw in these otherwise incredible pre-amps.
Not to be difficult, but calling the Pearl 2 flawed in design is a bit much. No insult intended, but post seems to be informational on how to misuse Pearl 2, sorry.
I made mistake of powering Pearl 2 with pre and amp on, selector mistakenly on phono. Got an ugly snap, but no damage. That taught me what I already new...power on source, then pre, then amp. Or, in my case as another pointed out, with selector not set to phono.
Maybe I am misunderstanding the issue, but why would one power on a source selector is set to with pre and power amp on?
Hope your clamp solves problem, but I'm not seeing need, unless other users in home who don't understand turn on protocols?
Russellc
As I have already mentioned.
In the case of the Arcam, all inputs are permanently connected directly to the input selector IC.
It makes no difference if the amp is ON or OFF. The input selection is digital.
Unless you are in the habit of disconnecting all the source equipment before turning on the amplifier, which is a bad practice.
