Peak Atlas DCA75 Pro
No info needed, connect the probes to the transistor and press test. Excellent device, essential tool for the discerning builder 😉
Get a test jig for SOT23 parts and use a breadboard with pin headers for leaded through hole parts. Solder leads for the probes to the pin header.
The hook probes take a hit eventually, get a spare set. https://www.peakelec.co.uk/acatalog/ups56-hook-probe-lead-set.html
Tip: use a clear lid or cover over the test jig to keep environment stable, even test each part twice to make sure. Test at the same time of day, close all door and windows.
Wear your best socks...
Reactions: STOXX and Mayday
Anybody have tips, tricks advice with the DCA75 Pro?
Data acquisition, storage, management, manipulation, spreadsheets?
I just acquired one and started messing around with it the other day.
I think I like it.
