PE06/40 replacement
I have two old Philips amps EL6435 in which the tubes need to be replaced. the output tubes are the rare PE06/40's. Philips created these tubes to be 807-alike. However they are not the same. How can I rebuild my amp to use the 807 outpute tube?
yep - basic specs on the datasheet shows them to be close to the 807/1625, including basing. The 5 pin base matches the 807 with 6.3v heater, the 7 pin base matches the 1625 with 12.6v heater. Haven't looked at hte curves to see how close they are in action, but they can't be too far off...
Circuit diagram here
