PDX-1.1000 Problem
Hi! I have a big problem! I'm pretty embarrased to say this but when I plugged my PDX amp i accidentaly reversed the ground and the battery wires. I was in a hurry and I didn't double check. All the 4 fuses got blown. My technician checked my amp and told me there was 2 MOSFET IRFB4227 that where blown. Every thing else seemed fine.
Could this be possible?
Or is my amp totally blown?(The amp still goes on but but the light flashes like it's giving an error code)
Can someone help me out!!
Thanks in advance
Well, with high power car amps the input current could be tremendous (i.e. >100A) and a diode for reverse voltage protection will be omitted because of the unwanted voltage drop and the overall decreased efficiency of the dc/dc converter. That diode would have a peak power dissipation of up to 70...80W (@100A, even with Schottky's, if you can get one with such a high amp rating).
I guess you're in luck that only 2 MOSFETs in the SMPS (S_witched M_ode P_ower S_upply) are blown and nothing more.
The IRFB4227 would be more likely to be used as output transistors. It would be VERY difficult to blow the output transistors by reversing the B+ and ground connections. Are you sure it was damaged by the reverse connection?
The outputs may have been blown before you wired it up and the fuses protected the amp's power supply from the reverse polarity.
