PCM67: NOS for a 1-bit DAC?
Actually, the Burr-Brown "Advanced 1-Bit BiCMOS Dual 18-Bit DIGITAL-TO-ANALOG CONVERTER" PCM67 is a hybrid (1-bit, multi-bit) design.
Datasheet here.
I once owned a Theta Chroma 396 (1996 model) d/a processor that used it ( downstream an PMD100 digital filter). Stock, the Theta sounds good, with a punchy, dynamic sound.
Interestingly, the datasheet for the PCM67 suggests:
The one-bit DAC was designed to operate between 96fs (4X oversampling) and 384fs (16X oversampling). But, it can be operated at 48fs
(2X oversampling) with slightly reduced performance
Anyone experiment with this DAC using NOS?
I have some PCM69s. Will drive them testwise with SM5842/DF1706 or AK4137 - so not NOS. Didn't finish the protoype yet...
But the PCM67/69 are extremely cheap and there is almost no risk of getting fakes 🙂
The PCM69 is NOT intended for hi-fi application. They are for music instruments (as noted in the datasheet).
Btw: Theta first began using the PCM67 in their Cobalt DAC (1993), which is similar to the Chroma (1996)
Cobalt:
Well, then please enlight me. What do you think is the fundamental difference between 67 & 69 soundwise?
Other than the timing I didn't find anything in the datasheet and regarding the "offset", where the switchover to the multibit DAC occurs, I do not expect any major benefit for either.
For what it's worth, I've ordered some '67 as well to have a base for jugdements 😉
From my experience PMD100 is the part that makes a difference. But in stand alone mode minimum OS is 2X. I think that is not possible without programming to get NOS from PMD100. If I am remembering well? Please correct if it is wrong? Once I was made a dac with PMD100 and PCM56. I can described the sound like in post 1 + very natural...
What do You think about that single +5V supply? All other proven, more than good, PCM dac chips have +/- supply?
PMD100 is unobtainium.
So, no sense in the regard of that topic at all, since PCM67/69 are €2 parts... They are - just cheap, none-mainstream and most probably not any good at all.
So its just for the pure joy of messing around with mid-oldschool pseudo-multibit thingies.
Kind of hollowman's avatar - doing such is not needed if you have 4" pipes... Europe FTW 😉
What would be the point of a non oversampling oversampling digital filter ?
PMD100 is not ordinary os filter. It is hdcd encoder at first place. PMD100 for my opinion is better sounding against other OS filters.Even when no-hdcd is coded.
And also very useful for I2S to BB format adapter. OS function with PMD100 is also better than other same-puposes devices.
So, in case of PMD100 OS is not the main point.
I don't think that what they meant. Last page on datasheet shows suggested hi-fi dac schematic.
And again quite a few hifi manufacturer used pcm69 for their product as such Trichord Pulsar Dac.
I have Akai AM-69 amp from early 90's.It has internal dac uses pcm69 and sounds more than ok.
