PCM56P Dac chip question
What confuses me about the pcm56 - and I would think all other dacs is that the output is 1 pin,
How can we get stereo with 1 point of output unless something else is there behind it to de code it. I should get the output after it turns into stereo right? Like at the opamp.
Thanks.
Srinath.
It's a mono chip, so you'll need two for stereo.
But the cd player only has one pcm56 in it.
Its a Yamaha CDX510u.
Thanks.
Srinath.
Perhaps it has two sample/holds after the chip? The very earliest Sony players worked like that,
Time-sharing the DAC between the two channels.
*** http://www.ti.com/lit/ds/sbas149/sbas149.pdf ==> Page 7 (Applications)
What confuses me about the pcm56 - and I would think all other dacs is that the output is 1 pin, How can we get stereo with 1 point of output unless something else is there behind it to de code it. I should get the output after it turns into stereo right ? Like at the opamp.
Thanks.
Srinath.
FIGURE 9. A Sample/Hold Amplifier (Deglitcher) is Required at the Digital-to-Analog Output for Both Left and Right Channels
It is actually written in their data sheet. Very very strange DAC chip =)
