PCM56K iv resistor value?
Hi, I did my first passive conversion with pcm56k and there is very much audible distortion. It increases with the music volume and decreases when the music is quiet.
I used this setting: I output: 750R i/v
The filter is 18 R in series and 0.1uf in //
There is also a 22uf output cap in case of DC current.
I saw schematics with 1k resistors so I choose 750R , lampizator uses 500R, and some other people use only 50R - 100 R. I might try 375 now.
Peace. Please answer only if you have a pcm56 I output resistor and knows what value is best for output level vs distortion.
For the others I noticed a funny fact: distortion sounds like 5 % - 10 % depending on output level, well with classical its very apparent, piano, midrange etc. BUT when I listen rock or electric guitar or Michel Jackson it's sounding ok – disco too.
18 ohm + 100 nF ? where did you see that ?
That is more or less the same as if you shunt the Iout directly with 100nF to ground
Can not work.
Analog filter for a single PCM56 per channel, 200 ohm I/V:
Or for a 750 ohm I/V:
put 10nF ll to R_I/V.
No series resistor.
Can not work.
Hi Bernhard ! Thanks for helping. I have 3 questions concerning your post.
1.
The 18 R + 100nf are to do a first order LP filter... Why it cannot work ???????
This afternoon before I saw your answer I used 375 R for I/v and the distortion was mostly gone.
2.
Do you use the schematic in the picture ?
3. Now my problem is with the BASS, it is cut, what is the possible explanation ??? Is it because the 375 R is too low and cut bass ? I heard that some people say it’s more bass when the resistor value is higher...
1.
2.
3. Now my problem is with the BASS, it is cut, what is the possible explanation ??? Is it because the 375 R is too low and cut bass ? I heard that some people say it�s more bass when the resistor value is higher...
1. 750 ohm ll Z of PCM56 give 455 ohm.
With 18 ohm and 100n you have -15dB @ 20 kHz.
Those values are totally wrong.
2. No, I made that schematic for a forum member, but I use a similar higher order filter.
3. I use 250 ohm per chip and bass is very good.
Are you sure that everything else is ok ?
Did you build a DAC or mod a player ?
Internal opamp disconnected correctly ?
Yes, I don't know how to calculate a filter and don't know how to calculate the Z at the output...
I modified a player, I already broke my old Sony by modifying it, and I posted that in another part of forum. This is the dbx5.
Everything is fine, no opamps, no pop or noise.
I try to build a first order LP and set the i/v resistor to good value and I aim for around 1/4 of power of the normal cd player, more is ok.
I think ill try it with 100 R for i/v, but what is the value I should use for the cap and resistor of the filter???
Right now I can't build that complicated filter in picture because I don't have a PCB right now.
Yes the player used the internal opamp, I didn't disconnected 9 - 10.
I have a problem :::::::::::::::::::
I tried it on my more sensitive system just with woofer speaker connected: unfortunately there is 3 mV 60Hertz pollution signal at the output of the dac , it is continuous even when the power is off !!!!, I need to disconnect the cd power cord to stop that 60 hertz pollution ...
That’s a huge problem ...:bigeyes: Ill try to disconnect pin 9 and 10
In the datas BB stated 200ohm IV resistor...
But, I useed 100 ohm resistor Riv to gnd.
with loaded OP (which is inside...) out of 2-3K
and without overheating dac chip...
addopted hafler based transistor OP as voltage amplifier
after to output...
PMD100 before dac...
I found 56' excellent really
