PCM2706 USB DAC - Interference/Temperamental Connection
ah yes, hehe i read that totally wrong the first time 😛
well good news! ive been fiddling around trying out some of your easier to implement suggestions and it seems much more stable now. in fact i've not yet been able to make it disconnect at all!
i've removed the inductors on the ground lines and hard wired them all together, added a 10ohm resistor to the base of the bc109 and a ceramic cap over the 100uF in the regulator circuit. the 10uH inductor is still in its current location as moving that was a little more work.
fingers crossed all my problems are now solved and i can start work on my enclosure 🙂
thanks so much for all your input. i reckon it was those inductors all along. maybe i should be on a physics degree rather than chemistry - it might serve me better in my hobbies 😛
browner said:
thanks Archwn.
to be honest i think your right and i'm pretty sure i couldn't tell the difference between bus and self powered especially with my speaker setup. suppose i was just tempted by the numbers and thought i'd give it a go as a challenge for myself, guess that gamble didn't pay off.
what i did hear of the DAC was mostly the output from the TDA1543 which i was really happy with. was going to use this as an upgrade over my creative sound blaster usb soundcard which seems subdued in the midrange around 3-4kHz ish. the 1543 was 1000 times better and sounded really sweet to my ears. would love to hear the pcm's output too.
thanks for your offer of boards, do you have a schematic for your design?
i thought i'd give my dead board another try to day - plugged it in and its working again!?!? :S that's despite me failing to get it to respond at all last week. this thing is seriously puzzling me, why does leaving it alone for a day/week suddenly fix it!? needless to say it lasted all of 13minutes and then disconnected itself again.
its so frustrating having something so close to perfect and yet utterly unreliable.
Code:
Apr  5 15:02:52 i2648 kernel: [35155.324000] usb 1-2: configuration #1 chosen from 1 choice
Apr  5 15:02:52 i2648 kernel: [35155.356000] input: Burr-Brown from TI               USB Audio DAC    as /class/input/input15
Apr  5 15:02:52 i2648 kernel: [35155.356000] input: USB HID v1.00 Device [Burr-Brown from TI               USB Audio DAC   ] on usb-0000:00:1d.0-2
Apr  5 15:02:52 i2648 kernel: [35155.528000] usbcore: registered new interface driver xpad
Apr  5 15:02:52 i2648 kernel: [35155.528000] /build/buildd/linux-source-2.6.22-2.6.22/drivers/input/joystick/xpad.c: driver for Xbox controllers v0.1.6
Apr  5 15:15:52 i2648 kernel: [35935.328000] usb 1-2: USB disconnect, address 5
Apr  5 15:15:52 i2648 kernel: [35935.440000] usb 1-2: new full speed USB device using uhci_hcd and address 6
Apr  5 15:15:52 i2648 kernel: [35935.640000] usb 1-2: configuration #1 chosen from 1 choice
Apr  5 15:15:52 i2648 kernel: [35935.640000] snd-usb-audio: probe of 1-2:1.0 failed with error -5
Apr  5 15:15:52 i2648 kernel: [35935.644000] input: Burr-Brown from TI               USB Audio DAC    as /class/input/input16
Apr  5 15:15:52 i2648 kernel: [35935.644000] input: USB HID v1.00 Device [Burr-Brown from TI               USB Audio DAC   ] on usb-0000:00:1d.0-2
Apr  5 15:16:44 i2648 kernel: [35987.744000] usb 1-2: USB disconnect, address 6
I really like this type of information. It pinpoints the fault in your system 🙂
I will just take that comparision report as a record. I will try self-powered soon anyway though. 😉
I did try 1543 and it is really good. sounds really relax and musical. the mids would match 1541 already. 😀
I use schematic from the datasheet. with a little bit tweak as it shows only 2706 self powered and 2702 bus powered IIRC.
I've got few cases from my friends like yours when everything works properly again after pronounced dead at the first time. sounds like a resurrection to me. :smash:
I also built a aw-d3. It kind of works - if there is no other USB device attached to computer.
Whenever I plug in a USB hard drive, the PC will stop or fail to recognize the aw-d3.
First I suspected the USB 5v supply. So I use my own regulated 5v to power the PCM2706 through a relay. And the USB 5v is just acting as trigger for the relay. But it does not seem to help at all.
My Musiland MD10 USB DAC does not have this problem, it is very stable.
Any one has similar experience?
I've only just picked up my AW-D3 again to use it in a digital amp and I also get intermittent problems, (actually, I thought it was dead as XP reported it dead until I tried a diff laptop)
I wonder if it is a current issue i.e. lowish current from some PCs giving borderline operation of AW-D3 board? Is there any way to check the current reqs of this board?
I'm thinking of removing the Led. Is the 74HCU04 needed as a level shifter (3.3V to 5V) for SPDIF output?
Otherwise I'd remove it also!
The USB spec requires that the DAC request the amount of current it requires from the host. As a bus-powered device, it should get 500 mA, which is plenty. According to datasheet, the PCM2706 draws less than 50 mA.
Since the problems are intermittent, I suspect L1. The intended purpose must be to separate grounds, but it may be hurting more than helping. I would try shorting it out and seeing if things improve.
There's also a lot of capacitance on the USB+5V line. The USB spec specifies inrush current and charge (100mA, 50uC), so some computers may actually adhere to the spec and disable ports when the inrush is exceeded. In this design there's almost 150 uF of capacitance (Q = CV = 750 uC) with JP3 closed. Fixing this requires either reducing the total capacitance (C19, C21, C23) to 10 uF, or redesigning the power network to do the proper sequencing.
Thanks guys,
I'll do what you suggest - reduce capacitance & short L1 - I didn't know that the problems with this board had already been solved - where can I find the thread?
BTW, I count 7 * 47uF = 329uF total capacitance - 5 caps on the PCM2706 & 1 on the Optical out & 1 on the 74HCU chip. As I'm only interested in SPDIF or I2S I'll be removing optical out cap & 2 caps on the analog out lines of the PCM chip. Can I get rid of the 74HCU chip altogether?
This thread mostly talks about a seperate Power supply & it's issues, not the USB powered probs!
I'll be removing the LED anyway as I had to do the same for my USB external drive, the Seagate Freeagent drive, to stop intermittent problems on it. This worked, even though there is an external PS powering the disk!
Hi JKeny,
Maybe you should get an external powered usb hub, this seems like an awful lot of work for what is apparently a very flaky usb port implementation in your pc/laptop.
Commercial products are tested to comply with standards and usually are pretty bullet proof. The amount of tinkering you've had to do to other devices is an indication of some sort of problem. I've not had any problem with USB drives, both HD and solid state, usb audio hardware, or any HID device on any machine I own including my now 8yr old Compaq laptop. (My two other machines are about 2 yrs old.)
I don't know if it's all the fault of my laptop - the Seagate Freeagent issue is a known problem & solution - I was just citing it as an example of borderline current draws causing problems.
Anyway, I'm going to take out the components as I only need the USB AW-D3 card for USB to SPDIF conversion to feed directly to my Panasonic SA-XR57 pure-digital amp.
Should be a killer combo, particularly as I've now discovered how much better audio sounds with the Linux Ubuntu distro (without any tweaks, so far)
Interesting... I also run one of the more recent Ubuntu distros occasionally and was surprised at the noticeably better sound quality than provided by bog standard XP on my home office desktop. The Windows kmixer really is a POS.. 🙂
Yep, that worked guys, I removed LED & left 4 caps in place plus I shorted L1, the inductor on the USB ground - don't know which did it but DAC works flawlessly now!
Now to download Ubuntustuduo-audio & get some high-end sound!
Edit: Oh one thing - what would be a good SPDIF output circuit for this board - I'm thinking of pulse transformer!
No! And L1 should not be there either! The proper way to do this is with a 4 conductor common mode inductor in the USB lines. Several vendors make these. You will need to break the loop somewhere else, the USB connections and chip grounds are not the right place.
