Bill of Materials
Line
No. Supplier Number
Customer Part No.
Description Qty
Ordered Qty
Shipped 1 <img title="RoHS: Compliant" alt="RoHS: Compliant">1
595-PCM2707PJTRG4
TI Audio D/A Converter ICs
Stereo DAC w/USB Ifc
US HTS: 8542.39.0000 ECCN:EAR99 COO:TW 2 2 2 <img title="RoHS: Compliant" alt="RoHS: Compliant">1
806-STX-3100-5N
Kycon Phone Connectors
3.5mm PCB STEREO BLK
US HTS: 8536.69.4040 ECCN:EAR99 COO:CN 2 2 3 <img title="RoHS: Compliant through Exemption" alt="RoHS: Compliant through Exemption">2
81-GQM1885C1H270GB01
Murata Multilayer Ceramic Capacitors (MLCC) - SMD/SMT
0603 27pF 50volts
US HTS: 8532.23.0020 ECCN:EAR99 COO:JP 5 5 4 <img title="RoHS: Compliant" alt="RoHS: Compliant">1
598-FCP1206C223G-H1
CDE SMD Film Capacitors
.022UF 16V 2%
US HTS: 8532.25.0045 ECCN:EAR99 COO:JP 5 5 5 <img title="RoHS: Compliant" alt="RoHS: Compliant">1
598-FCA1210C105M-G2
1.0UF 16V 20%
US HTS: 8532.25.0045 ECCN:EAR99 COO:JP 9 9 6 <img title="RoHS: Compliant" alt="RoHS: Compliant">1
653-B3SL-1022P
Omron Tactile & Jog Switches
6x6mm, 5.1mm Height
US HTS: 8536.50.9065 ECCN:EAR99 COO:JP 15 15 7
70-IR2.5610%
Vishay Common Mode Inductors
.56uH 10%
US HTS: 8504.50.8000 ECCN:EAR99 COO:MX 3 3 8 <img title="RoHS: Compliant" alt="RoHS: Compliant">1
757-TOTX177LF,T
Toshiba Fiber Optic Transmitters, Receivers, Transceivers
Toslink Transmitter
US HTS: 8541.40.6050 ECCN:EAR99 COO:TH 2 2 9 <img title="RoHS: Compliant" alt="RoHS: Compliant">1
647-PCS0J470MCL1GS
Nichicon Aluminum Organic Polymer Capacitors
6.3 volts 47uF
US HTS: 8532.21.0050 ECCN:EAR99 COO:JP 5 5 10 <img title="RoHS: Compliant" alt="RoHS: Compliant">1
647-PCS0J101MCL9GS
6.3 volts 100uF
US HTS: 8532.21.0050 ECCN:EAR99 COO:JP 5 5 11 <img title="RoHS: Compliant" alt="RoHS: Compliant">1
66-PFC08LF15-B
IRC Thin Film Resistors - SMD
15 OHM .1% 25ppm
US HTS: 8533.21.0030 ECCN:EAR99 COO:US 5 5 12 <img title="RoHS: Compliant" alt="RoHS: Compliant">1
66-PFC12LF22.1-B
22.1ohm .1% 25ppm
US HTS: 8533.21.0030 ECCN:EAR99 COO:US 5 5 13 <img title="RoHS: Compliant through Exemption" alt="RoHS: Compliant through Exemption">2
660-RN732BTTD1501F25
KOA Speer Thin Film Resistors - SMD
1/8W 1.5Kohm 1%
US HTS: 8533.21.0030 ECCN:EAR99 COO:JP 5 5 14 <img title="RoHS: Compliant" alt="RoHS: Compliant">1
754-RG1608P-332-BT5
Susumu Thin Film Resistors - SMD
1/10W 3.3Kohm 0.1%
US HTS: 8533.31.0000 ECCN:EAR99 COO:CN 9 9 15 <img title="RoHS: Compliant through Exemption" alt="RoHS: Compliant through Exemption">2
71-TNPW08051M00DEEA
Vishay Thin Film Resistors - SMD
1/8watt 1Mohms .5%
E 3 3 16 <img title="RoHS: Compliant" alt="RoHS: Compliant">1
815-ABL-12-20-D4HFI
ABRACON Crystals
12MHZ
US HTS: 8541.60.0050 ECCN:EAR99 COO:JP 3 3 17 <img title="RoHS: Compliant" alt="RoHS: Compliant">1
649-61729-1011BLF
FCI USB & Firewire Connectors
4P R/A RECEPTACLE
US HTS: 8536.69.4030 ECCN:EAR99 COO:CN 2 2
Keep in mind I bought enough parts to make two.
I selected the highest quality parts by spec, then selected the cheapest out of that bunch. It still sounds great.
Don't buy the SPDIF connectors. There's a resistor that wasn't in the parts list on the original site that's required to prevent it from blowing up. If you want that you'll need to redesign the board.
