Hi all, i have build PP UL EL84 amp Dynaco A-410 clone. I'm now searching the best combination of connecting my dac lampucera pcm1798 to it. I thought that a good idea would be to connect dac with El84's in balanced mode without phase inverter on ecc83 and use ecc83 as anode followers to gain signal from dac (+ and -) and put on EL84's. Maybe someone made such combination and would like to tell me how does it work or what should i change in this schematic. I didn't make correct calculations for resistor in ecc83 power supply, i wrote ~200k but i will check it when it will be working (correct to make 200VDC for ECC83). Please tell me what You think about this conception. Best regards
link to schematic: http://www.imagebam.com/image/936d01254980485
