For sale 8 B.B PCM 1704 K comes from a DAC Audio G.D Ref.7.1
can be sold still on the board or unsoldered (hot air gun)
90 Euros each PCM 1704 K (reduced depending on the quantity, negotiable)
Do they even work with i2s transmitters like WM8805, DIR9001, Amanero? Do you have an input diagram? I'm afraid they can only work with the proprietary Audio GD processor and then buying whole boards would be pointless, I only need four PCM1704-K chips.
I think both cards must receive a PCM signal if you want to use them without the Audio G.D digital card
If you want I have the digital central card , I used it myself with an Amanero.
Can I ask what converters you use with this digital Audio GD board, since you sell the original analog ones? It outputs PCM but as I2S?
I had removed the Audio G.D digital card which I replaced with a FIFO Lite with good clocks
You need an I2S to PCM card to use the 2 cards without the Audio G.D digital card.
