PCM1704 with Lundahl LL1588?
I'm waiting delivery of 2 X LL1588 in order to put them as DAC (PCM1704 ) output after first OPA627 - I/V converter.
- Schematic attached.
- Any hint/comments ? (Ok/Not Ok, better ideas?)
Thanks,
S.P.
I assume you are simply looking for a balanced output, but also trying to use the natural high frequency rolloff charateristics of the transformer to replace the reconstruction filter.
Just seems a pity to go to all this trouble and still leave the op-amp I/V in place.
I've tried to bias I/V OPA627 in class A with 8mA (using BC107B as current source).
And... sound improves gradualy!
Now thinking, is this the best operating point for OPA627 in class A ?
PCM 1704 is giving Iout +, - 1,2mA so, to be able to use passive I/V (resistor) + transformer, transformer have to be step-up type, that I don't have (at the moment) ...
