Good question. For me the most interesting question is, what kind of audible effects are there by a listening test (assuming the best possible approach for an I/U converter is in use for both versions).currently using PCM1702P DAC chips. is there any difference if I were to replaced it with PCM1702P-K chips?
kindly advise
tq
It would also be interesting to know if there are any audible differences between the early versions of PCM1702 from 1990 and later versions made in Korea - go to post #10 under
Burr Brown PCM1702...K, U-K, U, P, J ???
The pdf under
https://web.archive.org/web/2000083...r-brown.com/download/DesignSem/DesignSem5.pdf
don't provide the wanted information.
