O.K, Here u are, these are my PCBs for an aleph variant for everybody.
The Aleph L pcbs are the initial once not tested yet as i am in the process of adding a volume control and an input selector(digitiged driven relay stepped attenuator as the one in aleph P, and source selector using relays, my design).
Here u get the aleph-pcb and 2 masks that are the same, but made in 2 ways to be easier viewed.
I am sorry that the files are a not posted directly here but these are bit big but it was impossible to reduce the size due to the high resolution used in order to create a workable, printable copy.
http://briefcase.yahoo.com/bc/panos29/lst?&.dir=/&.src=bc&.view=l&.last=1
good work!
but what resolution should be when printing these pcbs ?
or what the actual size of thease pcbs?
thanks
thanks
size does matter
the dimensions are 20,26 X 9,84cm , resolution is 300,125 dpi
Anyway its printed in the correct size if u have a laser or a jet printer with 300dpi resolution, i use a HP 940c deskjet.
The output copy is perfect for creating the actull pcb.
Panos
Panos
Escellent job! I may just rebuild my Aleph L with your PCB next weekend. Its a much better job than the hand layout I did.
Thanks,
Mark Gulbrandsen
Salt Lake City
Thanks,
Mark Gulbrandsen
Salt Lake City
Your aleph 30 Power supply ?
Hi !
Nice Job ! congratulations...
on the "work" pictures i've seen your power supply using 2 capacitors, not 10000uF ? what is the value ? could you give me more info or graphic...
I have 2 nice 22000uF 63v electolytics maybe ... 🙂
Thanks in advance for your help...
Pa
Hi !
Pa
Thanks for the good comments!
these 2 caps are sprague 100.000ìf /30v moreover there are 2 bolted rectifiers rated at 30A/200v
Panos
Panos
4 instead of 6 x 0.47 resistors ?
Hi !
So, your power supply capacitance is a bit different compared to an original A30, and I have seen only four 0.47 resistors for R22-R27 instead of 6, do you try some other personnal modifications ? does it sounds different ?
Tia
Pa
Hi !
Tia
Pa
Panos,
very good work !
But why did not you save it as a GIF file - this works much better for graphics as the jpg, which is designed for fotos.
A GIF will be better in quality and much smaller.
PDF or postscript files should also be better.
All these conversions are done very easily with freeware programs.
regards
Klaus
very good work !
regards
Klaus
Add. file size and format:
Specially the L-pcb file suffered quite much by being saved as a jpg.
And converting it to b/w gif it will be 8 times smaller.
The Aleph30pcb is quite OK.
You surely did the layout work with a vector or a pcb design program, didn't you ?
So please, try to save it as a verctor file (like wmf, which would be best) or a graphic file (like a big scale b/w gif).
Another possiblity would be to save it as a postscript file (print it to a postscript printer as a file) or a pdf (best, because is will be in the right size and everbody can read it).
If you need help, send me a mail.
Klaus
Klaus
Dear Pa, there are 6 X 0,47ohm output resistors in my current layout. Only my old pcb had 4 as it was a copy of the aleph 3 and not the aleph30.
Dear klaus the program i use is an ancient one, but i know it very well to change it now. The aleph30 pcb was transfered to another one in order to save it as a bmp. But this was very difficult to do it as "boardmaker by tsien labs"(the old) has millions of save settings that i am not familiar with, so i cannot save it to other formats. Even trying to save it in gerber or postcript is very fuzzy. If u are familiar with all these i am open to any help so i can convert these to easier formats as gif. I can email u a copy of boradmaker if u can help(its very small and dos based). The aleph L is just a scan of the actuall printout thisfore is so bad, though workable.
Any help or modifications to my layouts are more than welcomed
Panos
P.S The next one to follow is the aleph L with stepped attenuator as the aleph P volume control (for the time i am waiting for the prototype to test the functionality, when done i will post it.
Panos
Panos
how did you get your jpgs then ? Did you print it on paper and scanned it ? Very inconvenient.
If there is no other file format saving possibility try following:
Choose a postscript capable printer driver from your systems driver library ( I use the Apple Laser Writer Plus driver) and install it.
Do not use the default connection (LPT1 usually) but choose FILE to direct the printing result to a file. Chose the right resulution and paper size etc. and in the POSTSCRIPT section choose ARCHIVEFORMATE.
If you print the result of any program to this "printer" your computer will prompt you with a save option. Save the result wherever you like as a *.ps file. Voila, you have created a postscript file, which can be looked at with postscript viewer, like Ghostview or transformed to pdf with Ghostscript (both freeware).
If you have problems, zip the resulting ps file (with Winzip or whatever) and post it to net somewhere (or send it to me per mail ).
I will convert it to pdf for all of us.
good luck
Klaus
good luck
Klaus
DONE!
o.K
Thanks for the help lohk !!!
I converted all my files to PDF but i cannot post these here or even at my yahoo page as they only accept gif and jpg.
Any proposals?
o.K
Any proposals?
C9 and C7 directly connected ?
On your Pcb C9 and C7 are connected beetween their - polarity, (like an Aleph 5).
but on the original scheme of the volksamp aleph 30 that's not the case.
Does this make a difference ?
Tia
Pa.
Tia
Pa.
Dear friend Pa, u are correct that these are the same as in the aleph5 but these make no difference in the final sound , at least in my subjective opinion, i have to say that i tried also the aleph 30 posistioning of these componets.what makes great difference in sound was the quality of the 220uf input capacitor were i settled for an ELNA cerafine.
However if u prefer different positioning of C7 u may convert it very easily. C9 is common in both designs.
Yours,
Panos
Yours,
Panos
Finally Done!!
O.K!!
I finally did converted the postcript files to pdf!!
I also zipped these so i may be able to post these to the forum as they do not accept pdf files.
The 2 contained files are: 1) aleph30pcb (pcbs for L and R channel so these can be mounted facing each-other kinda symetric)
and
2)aleph30-m which is the mask, for the component placing, using the component numbering system of the original aleph30.
The ones to follow are the DC protection circutry as well as the soft start.
Later the complete pcb of the aleph-L including the stepped attenuator as the one found in the aleph-P(using simple A/D conv. and 6 relays.
Finally I would like to thank, once more, Mr Nelsson Pass for sharing his knowledge with us.
Sincerely,
Panos
O.K!!
and
Sincerely,
Panos
ELNA
To be more specific the ones i use are ELNA SCILMIK, the ones with brown sleeving and the leetering in gold. Unforunately these are sorced locally(Athens) for about 3 euros each, not what i call cheap but surely worth their money to the last cent!🙂
Both
I mean the input capacitor C11 as well as the feedback C10.
These 220uf elna silmiks seem to have a better sound, at least to my subjective opinion, i also use these for C9.
Panos
Panos
- PCBs for Aleph30 & Aleph L !
