This is going to seem like a super dumb question (novice here...), but...
With something like Rod Elliots p97 pre amp, where all the pots are pcb mounted, do I HAVE to mount the pots on the PCB? For instance, if I wanted to use stepped attenuater(s), or if I didn't like how the pots we're spaced, could I still use this pre amp pcb but use as short wires possible to connect the pots to where they we're supposed to mount? Obviously I wouldn't use pcb mount pots.
Thanks in advance.
Thanks in advance.
Where the pots are gone?
Hi Massapeal!
Yes you can!
But please...short wires!..
Jorge
Hi Massapeal!
Yes you can!
Jorge
