Hi!
I am looking for somebody who could make DIY prototype PCBs.
Is there anybody???
Greets:
Tyimo
Is there anybody???
Greets:
Tyimo
I can make prototype PCB's - the PCB would be 1oz copper on a FR4 substrate, 2-layers, solder-mask, and through hole platting. Here is an example of a board I made prior to solder-masking. I can also provide PCB design services.
I wouldn't necessarly call these DIY PCB's - although if you have deep pockets.
They are milled on a LPKF C100/HF. There are a couple of methods for DIY through hole plating. The easiest is rivets:
Dangerous Prototypes LPKF EasyContac rivets for vias
Another route is using conductive ink - lpkf sells a "consumable kit" that has everything - here is a video:
YouTube - PCB Through-Hole Plating without Hazardous Chemicals
In general - LPKF is super over priced. You can get the conductive ink from thinktink.com and he has a good discription of how it is done. LPKF stops at application of through hole paste / conductive ink. This is ok for "short term" PCB's - but if you want it to last you need to electroplate it which actually is not as involved as you would think. Here are links to the coductive ink and electroplating processes.
Think & Tinker Instrument Prototyping
Conductive Ink Application - Holewall Activation
Thinktink has great prices and there stuff is super high quality. We got our vacuum table from clampusystems:
Vacuum Tables, Vacuum Clamps, Vacuum Pods and T-tracks from Clampusystems.com
They fabricated a custom built table that is perfect - hooks up to a shop vac. If you do get a table from them, tell them Max from the University of Minnesota referred you. Ours cost $600. If you are on a super tight budget, you can used just a standard shop vac with a sock over the end to suck the paste through.
lpkf c100
Hi, we have a lpkf c100/hf machine, we need the ini files, we bought on ebay w/o computer, thanks to help
Quality of PCB is very important for the performance of audio systems. Please look at this thread:
http://www.diyaudio.com/forums/sili...ics-store/198350-pcb-fabrication-service.html
I recently tried PCBWING.com PCB Manufacturer, Quick Turn High Quality Printed Circuit Board Discount, Stencil, Online quote and order for the first time and found their product/quality/pricing/service very atracive. E
If you're looking to make a prototype pcb I would recommend Spirit Circuits "Go Naked" service. I've used thier service a couple of times and they are very good, and best of all the service is free.
Spirit Circuits - Go Naked - Free 48-hour prototype service for PCBs
- Design & Build
- Parts
- PCB maker
