PCB layout based on the Linn Intek Phonostage
Since you have laid out symetrically why not put SW1 down in the
center? (shortens the input trace and make the rest even)It might also be good if you can do a ground pour instead of the many parallel ground return or star ground.(red). singa
PS the mounting holes look too close to the edge of pcb,might be good if you allow more
clearance between trace and hole that means making the pcb slightly larger and for mechanical
soundness or strength as pcb may crack when screws are tightened.
