Hi, I am wondering if anyone are interested in any PCB group buy? I can organize it. I can even solder SMD components for you if needed 🙂
I will run any PCB group buy for a minimal of 10 PCS. I can also run components group by as well.
So, what is this PCB group buy for? Is it for a DAC? Preamp? Seems like you forgot to mention the main purpose.
for anything. if more than 10 people are interested on a PCB or set of components, i can run the group buy.
Maybe a Leach? Not sure if most of the parts can be sourced though Mouser or main stream sources or the interest. Seems like a nice well documented amplifier, not sure of the versions.
http://www.diyaudio.com/forums/solid-state/178530-tribute-late-prof-leach-lx-amp-voltage-stage.html
http://www.noermoelle-rasmussen.dk/Delta-audio.com/Leach-Clone.htm
http://users.ece.gatech.edu/mleach/lowtim/
Leach SuperAmp Plans
Also ebay: 280495327394 , 280451174872, 280502227442 ?.
Hello I can help you in GB for PCB at the best value.
We had already offered more than 500 free PCB for amplifier, headphone amplifier and power supply on this forum. You can see a lot of feedbacks about the quality.
I may give it a shot later and attempt a group buy. Right now I have other things to put together but it is on my list. I would probably try the delta boards, and check if the BOM can be sourced from, say Mouser or digikey (In the USA). International I don't know maybe farnell.com ?
- Group Buys
- PCB Group buy
