It's pretty tough to lay out a printed wiring board without knowing more about the components, and the mechanical constraints (dimensions) on the completed assembly. For starters, is this a through-hole, or surface-mount, design? I can make some reasonable guesses about the resistors, but capacitor dimensions vary widely depending on capacitance, voltage rating, and type of construction.
Dale
Dale
Hello!!!
Urgently need a PCB for this volume, and loudness control!😕
I'll be very, very grateful to the one offered here PCBs for this pattern.
Circuit has given down!
Many thanks in advance!
i have made this circuit and im using it as a pre for my classB amp at home. its not bad.
i have the pcb if u wish. just tell me.
Hello harp, sorry for my bad english, i'm from brazil... i want use for my class B amp too... If you can send to me or post the pcb layout i will be very very greatful ....i have made this circuit and im using it as a pre for my classB amp at home. its not bad.
I'm having trouble navigating the forums, I read many pages until my eyes ache and do not always find what I want .... I'll be very happy if you can help me
- PCB for Volume and Loudness Control!!
