I am in the progress of makin´ a PCB for a stereo power amp module based on the TK2350 chipset. The PCB originates from a Tripath demo board but with some mods, including space for other selection of components (caps), bridging and possibly an optional different feedback path. The chipset drives external, onboard, MOSFETs and is rated at 2x300W into 4 ohms @+/- 45 volts or 1000W 4 ohms bridged. However, the chipset is rated to an absolute maximum of +/- 70V so there is some margin for boosting the power even higher.
I expect the PCB:s to be ready in mid november and they should have a price of around US$15. Everything needed for a complete stereo power amp module should be less than $100 but I have not made a proper calculation yet. Of course the cost depends on the components you use and where you buy them.
There is still time if you want to suggest changes for the PCB.
Yesterday I set up a new web site for this project and others. http://www.41hz.com
Sounds like a very interesting project especially for subwoofer plate amps(amp2) or bi- triamping.
If I wouldn´t have so many amps on the bench already I´d certainly be in for a set. I still might be...
Keep us updated!
Keep us updated!
janaf, just checked your home page. You write 70 g/m2, don't you mean 70 um (micrometrer) thickness?
BTW: I like your domain name 41hz.com
I'll probably be in the market for a 1000W amp here soon... If prices for one of these (under $100) are as you claim, then I would definitely be in.
As a side note, I may have a more immediate interest in your 2x100W amp...
The datasheet for the TK2350 gives +-65V max so with 50V secondaries, 600/1000VA and a quiescent current of only 60mA per channel you might exceed even 70V slightly.would a 2x50v 600VA or 1000VA fit that board?
That of course depends very much on the transformer itself but personally I would take a smaller one (lower voltage).
See datasheet for more info.
- Class D
- PCB for the Tripath TK2350 2x300W chipset
