Pcb for MUR860 (or some else TO220 diode), recitier bridge
I have made a pcb for four TO220 diodes including snubber network with only a capacitor or a capacitor+resistor. The diodes can mounted on heatsinks and the pcb has 70 um copper, good for 50-80 A. Room for PHE450 heavy duty caps from EVOX RIFA. Note also that I use the best audio connector in the world, the patented Wago from Germany.
http://home.swipnet.se/~w-50719/hifi/rfb01
Joined 2002
Hi Peranders,
I would like some as well for some low power applications.
I had also been looking for a board that would allow me to mount all for the diodes on a single heatsink in a single plane. Peter Daniel made some for his A75 to Aleph5 conversion, but I've never seen them available commercially.
Joined 2002
Hi Jason,JasonL said:is peranders going to make and sell some pcb's?
He is selling the full bridge, but if we ask real nice, maybe he'd be willing to sell just the boards to some of his friends at DIYAudio.
Hi peranders,
would You mind to explain why this is the best (audio) connector?
I have used this connectors in a project 5 years ago but wasn`t aware that they should be "so" good. I`ve simply choosed them because they`re avaible in nice different colours and because they fit in this particular application so well.
Usually I rather shy away from spring contacts and feel more comfortable using solid srew-type connectors but this is just because of my gut-feeling and actually there might be some good reasons to use those Wago.
roddyama said:
Hi Jason,
indeed one would be led to think so, given the title of the thread.
Joined 2002
now i just need a price. i like them boards. there nice. i dont have any of them cute nice looking heat sinks though : O (
I'm selling just the boards.... see the link above.roddyama said:
Hi Jason,
The heatsinks are Austerlitz or Redpoint, quite common.JasonL said:now i just need a price. i like them boards. there nice. i dont have any of them cute nice looking heat sinks though : O (
grataku said:The capacitors are too narrowly spaced. In fact, 8 RIFA won't fit at all.
You don't have to put 8.
C1/2/5/6 are the caps usef with R1/2/3/4 for snubber networks.
C3/4/7/8 are used alone to bypass each diode.
You use one or the other possibility, not both.
Rodd you can use my pcb and mount the diodes on the solderside and then bend then 90 deg in order to fit a plane heatsink.roddyama said:Hi Peranders,
