Hi Yusuf
i would be very interested in the LM4780 IC if you still have it. can you email me at fdehlvi at gmail dot com if you are willing to give it to me...
thanks and kudos for keeping the diy spirit alive
love,light and peace
farhad
farhad
HI
Is there any source of LM3886 chip in india , preferably in Delhi
I have made a PCB but not getting the chip.
regards
regards
Mumbai should have everything. You might need to serach. One of the earlier posts on another thread had some shop names.
Try searching for it.
I'm surprised that Delhi has no suppliers. Searching could be quite daunting with millions of tiny shops. I always get lost . On later trips I used to step into every shop one after another and mark them off on a list by shop number to make sure I do not step into the same shop again.
No point asking the shop keeper. I've never got any suggestions from any one of them. The standard reply was " we don't have ". Do you know who has it ? --"sorry don't know" ( then I get an indifferent look that says "now get lost we are busy " ).
Any Mumbai members with current info ?
Cheers.
Cheers.
I got a quote for about 200 bucks each for the LM3886 . But it's been about 5 weeks and I haven't seen a single piece yet ! Maybe the guy has got it mixed up with the LM4780 which I also asked for. I'll have to check it out. Has anyone actually bought one from their local ( Mumbai or Bangalore ) market ?
If we do have a real supplier he will show interest in larger quantities. Say a 100 minimum .
I'd suggest that we search for a reliable supplier who can get the part and then organise a group buy with a total minimum of 100 pieces . It will be much cheaper than getting it from abroad.
Hi Ashok
You have said it all. That is the reason I wanted exact shop number so that I can just go and buy the Chip. Can't move around
shop to shop.
regards
shop to shop.
regards
I forgot to add that the actual standard answer started with " How many pieces " , no matter what I wanted and even if they never sold that part .
If it was for a couple of pieces etc. , the answer was ' Sorry don't have'.
If it was a hundred or more then they would start calling other shops on the phone and give a much higher qote if they found a stockist ! Needless to say , we would be never be able to find out who had it !
I've bought single-unit quantities of the LM3886 from Chetan Electronics on S.P. Road in Bangalore for Rs.200/-. This was the isolated plastic tab version, not the metal tab version. The price may vary depending on availability.
YMMV, but the ST TDA7294 at Rs.85/- is a better deal for a gainclone. I've also got a PCB for the TDA7294 that is similar to the reference design in the ST datasheet. I'm planning a modified Class-G version, but it's very early in the design stage.
JPS said:HI
regards
🙂 JPS In LR Mkt Try Kamrite Electronics & If u need exact add just PM me ill give u the phone no & contact persons name from where i have purchased 4 Nos. LM 3886T
This is the shop from where i have purchased LM 3886 In DELHI
Add: Micro Electronics
Shop No-34, Lajpat Rai Market
Delhi - 110006
Ph: 011-23865048,23862808,
Mr. Pradeep Gandhi.🙂
Hope this works🙄
Delhi - 110006
Hope this works🙄
lm3886
i have 9 lm3886 available ready to give for rs 200each , 5 metal package and 4 isolated
i am from kerala,
i am from kerala,
I have 15 nos of LM3886 metal for sale.Rs 200/-each
pls send email to get a list of audio low signal IC's,Power Opamps from Texas inst,Burrbrown, National,Philips,Maxim etc
Hi Sivan
I am in need of 2 LM3886 and 15000uF 65V Electrolytics. Can you give me your contact number.
Hi Sivan,
Why you're searching for PCB, Why dont make it yourself.
Once done,it is very easy. just print your design onto
Vinyl sticker back paper using a Laser printer,Which has a wax coating on it to avoid sticking.Actually it is a waste paper and it dose not take time to transfer,just iron it and after cool it to room temperature now it is ready to etching.
i made many PCB's for LM3886 using this method's, its 100% success.
matthai
matthai
Hi Sivan,
matthai
from where can i get vinyl sticker back paper can u show me the image plz.thanking u
You can use any shiny sheet and laser printer.
I have one basic design for 3886/76
Single sided, you can make double sided too at home...
adult image
adult image
for toner transfer you can use ART paper with laser printer and is available in most stores
there is a listing for lm3886 PCB in http://www.ebay.in
hi. is your LM3886TF still available?I have 15 nos of LM3886 metal for sale.Rs 200/-each
still available the isolated type? thankslm3886
i am from kerala,
Dear audiobits79,still available the isolated type? thanks
Maybe someone could help / guide if you specify your location.
- Chip Amps
- PCB for LM3886/LM3876/ LM4880 in INDIA
