hi,
i checked and found out that the protel 2.7.1 is very old version.
why it is used instead new version ?
is there any catch ?
any other good software for PCB designing ?
Hi Kristijan, could you tell me what the hole centres for mounting the fets are on your Aelph V PCB and Ver II of your Aelph II PCB (3 pc. Set)?
I am trying to see if they will fit in an existing chassis before I order the boards.
Anthony
Anthony
Joined 2002
Hello,
Chorei,
The Protel 2.7.1 is much cheaper than the newest version, and the final results are the same.
You can also use the Tango, Eagle, P-CAD ....
Coulomb,
The spacing on Aleph 5 , drain to drain, is 24,5 mm (0,9683 in).
The spacing on Aleph 2 - V2 (3 PCB set), drain to drain, is 43,5 mm (1,7193 in).
Also, the dimensions of all PCBs are stated on the website.
If I can be of further assistance to you, please feel welcome to contact me again.
Best regards,
Kristijan Kljucaric
http://web.vip.hr/pcb-design.vip
Chorei,
Coulomb,
Best regards,
Kristijan Kljucaric
Joined 2002
nice i stil have my protel 98 with my spacial version both... but till this day i still have not figured out how to make a pcb.. id like to though..
J' is there any one that can help me with the protel 98...
JasonL said:J' is there any one that can help me with the protel 98...
Open the Protel help, and follow the tutorial. It is really helpful, and easy to learn, how to use the SW.
It is teach you step-by-step, how to create your PCBs.
I did it also.
