Passive Line Level High Pass
I need a temporary high pass filter or rumble filter for a subwoofer set at 40hz until i can get something active sorted out.
I had a look at: http://en.wikipedia.org/wiki/High-pass_filter Which seems to give the circuit and the equation, however i have no idea what sort of resistor value to use in order to derive the capacitance required.
Any help as to what sort of resistor value i should be looking at for a line level filter?
Thanks for the help, however i found a digital 250 band equaliser plugin for winamp which i will be able to use when i need the high pass filter. The filter can be set for flat response at 39hz and to be 60db down by 35hz.
http://coyote.freeweb.hu/winamp/dsp.cgi
I will probably build a steep opamp filter however since it just so happens the sound source for this little event is a computer running winamp. I have tested the plugin with a spectrogram and it does work effectively at cutting out low bass.
