Voltage loss with even a second order circuit will be fairly serious.
As shown its effectively cascaded first order filters and cannot
provide any control over Q, its not really a second order circuit.
3rd and 4th order versions will have horrendous voltage
loss and will be nowhere near real 3rd or 4th order filters,
just 3 or 4 cascaded first order filters.
The high pass version can be emulated by manipulating the
input capacitors of the amplifying chain and is a waste of time.
For passive filters higher than 1st order you need some inductors.
🙂 sreten.
🙂 sreten.
i don't care about loss i can listen without any problems with 100K resistor(connected 😛c>line level passive(R100K) >preamp>amp>speaker)
i just want to know what is the formula?
Bytheway don't know does it control Q but with Second order i could hear less high frequencies than with First..
P.S. could you give me link to crossover with real 3rd and 4th order BUT not active and without INDUCTION...😀
RC PLLXOs are not suitable for anything over 2nd order (and that is pushing it) because they get real droopy (ie really low Q). If you need higher order you need to go to an LC network. And the size of the Ls needed means sourcing them gets tricky.
Marchand is selling kits http://www.marchandelec.com/xm46.htm
dave
dave
