Hi all
In the process of building an active horn speaker setup. I have the 3 amps needed and was thinking about using simple passive filters on the input of each amp, are there any reasons not to try this?
I want the bass to roll off at say 400 hz with a first order slope so a simple resistor and capacitor filter on the amp input could do this, correct?
What do you think......
Sent from my SM-T800 using Tapatalk
Should work fine, as long as driven from a low source impedance.
(no passive volume controls, or preamps like the Marantz Model 7 with its control on the output side)
on the input of each amp. I want the bass to roll off at say 400 hz with a first order slope.
This can work well if the drivers' bandwidths extend well beyond the crossover points.
Be sure to take into account: differing driver efficiencies; differing amplifier gains;
preamp source impedance; amplifiers' input impedances. All these will affect the results.
The drivers should also be time aligned.
