Hello,
Could you confirm the value for the ALPS RK27MC please?
Would you also consider a complete kit (including the alps part)?
Thank you, Julian
Thank you, Julian
Hello Verteran, great work.
I'll take a premium gold with blue backlight.
I will PM you.
Thanks !
I will PM you.
Thanks !
Hello Veteran,
your design is great and it provides additional opportunity to extend, i love it
If it possible to get the µC Code i want try to extend it to get following additional feautres :
- use Con3 to additional switch 4x Digital IN with IR
- use additional REL2 to Bypass the Alps (Home Theatre Mode)
- use additional PSU and additional On/Off REL1 to trigger external Amps
I have added a free hand sketch to illustrate.
What do you think about ?
Thanks regards
Marcus
Thanks regards
Marcus
Hello,
Thank you, Julian
I recommend a 10k - 50k potentiometer – this value will be OK for most applications. If you can't buy a pot (the cheapest are on e-bay) - let me know. I will order one for you.
Hello Veteran,
Thanks regards
Marcus
Marcus, I sent you PM. As I said I don't publish source code for my projects because I create my own libraries (which is time consuming). Of course you can use CON3 to controll something alse than relays.
I know about that, therefor no problem with this.
Marcus
On Friday I sent a first batch of kits - below you can find the address to track your package:
?ledzenie przesy?ek - Tracking - Poczta Polska - www.poczta-polska.pl
Veteran,
got my boards today. Thanks! 🙂
They look good, as do all the parts. Too bad a I won't have time this weekend to work on it 🙁
I'm sure there won't be any issues, I'll let you know if I find anything... 😀
Veteran,
Good to know that package arrived without a problem 😉 If you will have any questions in the assembling process feel free to ask.
Hi Damian,
Got my boards and parts, all look very nice.
The boards are really top notch, where do you have them made ?
I'd like to try this for my next Amp project.
I have used "printed.cz" in the past and the boards are good but last batch was not really up to the standard of yours.
Thanks once again for great work,😎
Hello,
Damian send my pakage at May of 06 and since May of 7 it is "out of polish territory" (Last Track and Trace entry), but it is still outstanding up to now 🙁
Is there anybody out there who also still wait for the package or did all receive it ?
Marcus
Marcus
UMarcus,
situations when post loses a package happen very rarely. This status means that your package is somewhere in Germany (probably there is no information exchange between those two offices so they can track it to Polish border).
Fortunately all packages are registered and insured - I will place a complain in my post office after the weekend.
Hello,
finally i find time to assemble and test the board and i'm very happy with it !
No problems during assembling / building and initialize start up of the kit !
Once again, many thanks to veteran for do this great job and provide it to us !
UMarcus
UMarcus
At the moment it is only a "breadboard" or better "woodboard" 🙂 , i'm still waiting for the DAC Pcb which also mount on the breadbord, if all work as expected i'm looking for a chassis to build my "passiv preamp with dac"
I'll post some pictures later on.. at the moment i'm in the company to do my job 😉
UMarcus
UMarcus
- Analog Line Level
- Passive (active) preamplifier with selector (motorized ALPS, IR)
