passive/active pre amp ?
Some complication is inevitable. If you are willing to tolerate a 10 Kohm I/P impedance (which happens to be IHF "standard"), the problem is (IMO) relatively easy to solve.
A 10 Kohm log. taper control is cap. coupled to either a common cathode gain stage or a cathode follower. The cathode follower always drives the downstream load. The cathode follower is switched between the volume control and the common cathode gain stage.
Forgive me. I can build from a circuit but im far from an expert when it comes to the technical. Is there a disadvantage to using a 10k I/P ?
You can do it guitar amp style and just switch a bypass capacitor on the common cathode stage cathode resistor in and out of circuit. Advantage is clickless and popless switching and just a DPST switch for stereo; disadvantage is the resulting gains might not be what you are looking for.
A lot of tube equipment can't deal with a load that awkward. OTOH, any commercially distributed SS component, like a CDP, will do just fine.
The reason for the 10 K I/P is adhering to the 1:10 rule. To avoid HF info. loss from an interaction with the Miller capacitance of a common cathode triode, the grid to ground resistance is best kept <= 100 K. The wiper of the 10 K volume control is coupled via a 0.47 μF. cap. to either the common cathode gain stage or the cathode follower.
Got ya. Thank you for taking the time to explain.
What is the gain of a 12B4A common cathode stage with bypassed Rk?
What is the output impedance of a 12B4A common cathode stage with bypassed Rk?
What is the gain of a 12B4A common cathode stage with unbypassed Rk?
What is the output impedance of a 12B4A common cathode stage with unbypassed Rk?
I never bothered to "run" the numbers. The 12B4 datasheet says the plate resistance is 1030 Ω and the μ is 6.5, which I find to be highly satisfactory.
