I have the Zen V4 PCB boards with Q pack,(bought from Pass), with all the specified parts expertly soldered including the Mosfets with silipads. I have the 2 specified Plitron power transformers, the 3 specified bridge rectifiers, the 2 Panasonic TS series 27000 uf/63 vdc filter caps, High quality Gold RCA input connectors, heavy duty dual power supply toggle switches, and fuse holders. I have a welded aluminum chassis, made by a local professional welder, made from 1/8" high quality aluminum plate. It has 2 foot long by 7" high by 5 1/4" thick, finned aluminum heatsinks welded along each side of the chassis. It has a top cover from the same 1/8" plate aluminum. Top cover is drilled for mounting, but cassis will need to be tapped to accept screws.
The heatsinks are from MECI, and are the same as the ones used by JAG in the Pass gallery under Zen Ver 4.
I have over $140.00 just in the chassis.
I estimate well over $400 in parts. Nothing was ever wired , but trannys, switches, fuse clips, filter caps are mounted in the chassis, and pcb's are stuffed.
Due to wifes illness, I have no time to finish the project.
Reasonable offers welcome.
Thanks,
mg16
Thanks,
mg16
Eamil me, I am interested.
I am also0 just finishing up a Zen V4, but am already looking at parts to build a low (10 - 20 watt) Aleph soon. The hardware would work great.
TIA,
George (tomlin@ev1.net)
TIA,
